| | | Forums66 Topics128,052 Posts1,055,738 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 13 New Guy | | New Guy Joined: Mar 2013 Posts: 13 | How do you remove the dash knobs and headlight switch from a 60 Apache? Thanks | | | | | Joined: Mar 2001 Posts: 1,181 'Bolter | | 'Bolter Joined: Mar 2001 Posts: 1,181 | You need to reach under the dash and you will feel a pin with a spring on it, push that in and it will release the shaft. | | | | | Joined: Jul 2008 Posts: 1,262 Shop Shark | | Shop Shark Joined: Jul 2008 Posts: 1,262 | This video shows the pin you need to depress, even thought the video is for a '73 truck.... Hope this helps! | | |
