1 members (JW51), 186 guests, and 1 robot.
Topics128,081
Posts1,056,077
Members48,434
#955812 07/11/2013 11:45 AM
Will be replacing a connecting rod on my 216 later this week. want to make sure I have all parts on hand. In the diagram I see no clip or O-ring to hold in the wrist pin.
Are there any? This is not just sitting on the bushing ?
Aren't they pressed in?
Give me ambiguity
or give me something else
There is a pinch bolt at the top of the rod that locks the pin.
My Blog
ok so it is the connecting rod bolt that locks in the pin -
Yes. See link Bottom left of page.
My Blog
Riding in the Passing Lane
Some of the rods can be replaced without pulling the head. Loosen the pinch bolt. Unbolt it from the crank & pull it down just enough for the pin to clear. Then slide out the pin. An old timer taught me this many years ago & I did it once.
1972 Chevy c10 Cheyenne Super
That has to be one of the coolest features of these old engines. I also like the shims that you can remove to tighten up loose bearings rather than spending big money for a total tear-down, and machining the journals.
Also I read to replace the lock washer for the bolt when installing the rod to the piston - they get brittle.
Yes indeed - I test fit everything lightly and sure enough the washer split - great tip.
