1 members (homer52), 66 guests, and 4 robots.
Topics128,072
Posts1,055,906
Members48,429
Junior Member
Junior Member
I have an all-original 1953 3800. I have owned it for some time and am pretty familiar with the mechanicals. But... My fuel gage did not function and I found the float to be sunk. I installed a new float and all worked ok but soon it began to show "full" all the time. I have found that if I fiddle with the wire and terminal that goes into the sender then the gage registers properly. However no matter how I tighten or loosten or fiddle with this connection in a few miles the contact is lost again and tank reads full. Where is the problem?
Maybe the wire is broken internally and only makes contact between the pieces when you mess with it. Try jumpering around it.
It sounds like you're grounding out somewhere.
Is the wire original?
is there a ground wire from sender to body it needs to be grounded
With no sender hooked up, you should get a full reading. If you ground the sender wire, it should read empty. It sounds like you could have an intermitent open in the wire.
I believe that there is a ground wire that attaches to one of the hold down screws on the sender rim. This should be grounded on the bottom of the floor.
1951 1 Ton Completed
