2 members (TUTS 59, 1 invisible), 89 guests, and 0 robots.
Topics128,134
Posts1,056,402
Members48,441
#95562 05/08/2006 1:11 PM
have converted to late model 235 and 12v system wanting to maintain original guages. How best to accomodate 12v with regard to amp meter and fuel guage sender? Any suggestions would be appreciated.
"You are only young once, but you can ALWAYS be immature!"
1938 Chevrolet H/C 1/2-Ton
Hey Lobo49,
The ammeter dosen't give a hoot about voltage and will work fine with twelve volts. In order to make sure that you don't fry the fuel gauge, you will have to install some sort of resistor on the fuel gauge. The Runtz Gauge Resistor from 5th Avenue is one such resistor and possibly the best one for the application. Please see the links sections of this site for 5th Avenue's contact info.
Good Luck With Your Project,
Jon
Tnx Jon for your help. Went to Website and found exactly what I needed. They even had a solution for my heater blower!!
