5 members (Gdads51, Otto Skorzeny, Dave51Chev, klhansen, 1 invisible), 74 guests, and 2 robots.
Topics128,032
Posts1,055,519
Members48,425
#948632 06/06/2013 10:08 PM
What is pretty much the standard rear axle width everyone puts under their trucks? I'm looking for a rear to swap my original out with. I read that a lot of people use camaro rears?
BossHawg #948708 06/07/2013 8:55 AM
It depends on what year truck you have. For early trucks; 36-46 or so, a 4wd S10/Blazer rear end is the correct stock width. Later models are wider.
1939 GMC AC-102 Long Bed 1/2-Ton
In the Legacy Stovebolt Gallery
More details in his DITY Bay
1940 Chevy WB Series 1.5-Ton
BossHawg #948718 06/07/2013 9:30 AM
70-81 Camaro rear under my '53.
BossHawg #948760 06/07/2013 12:47 PM
BossHawg #949021 06/08/2013 7:57 PM
Im running a 4wd s-10 under my 46,fits perfect with the stock 1 3/4 springs and welded on perches I got from jc whitney
That rear, a 10 bolt, will fit both 1/2 ton 3100 and 3/4 ton 3600. Also the axles will accept the 2002 Firebird disc brakes.
~Jim
alkay3 #949305 06/10/2013 11:42 AM
its a 1954
BossHawg #949366 06/10/2013 4:29 PM
Another issue is the lug count. The Camaro is a 5 lug, (it is 62.5") but if you've been reading about this fit you will know this.
~Jim
I figure it would probably be best to go with camaro rear since the front is already corvette
BossHawg #949570 06/11/2013 10:40 AM
Thanks for all the opinions guys!
BossHawg #954919 07/07/2013 12:39 PM
Some of you guys that have the camaro rear under your trucks I would like to know what kind of changes you had to make as far as wheel options. I know there is a 60" and a 62.5" camaro rear so please let me know the width of the rear you have. I would figure the 60" would be to narrow seeing as how the original had a pretty narrow track to begin. I don't have the bed on my truck so I'm left with asking questions. Someone had posted a diagram a while back and with drawing of the whole truck and measurements and I wish I could find that again but haven't been able to locate it.
BossHawg #955327 07/09/2013 9:56 AM
Boss,Hawg,
What truck do you have? I assume it between 47.5 and 53. My 51 3600 has a 80 Camaro 10 bolt. It's been a few years but I'm sure it was 62.5. Be advised, the 3600 frame is 11 inches more narrow than the 3200. That, I believe is only helpful if you want to tub your bed.
~Jim
BossHawg #955445 07/09/2013 6:50 PM
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
BossHawg #955605 07/10/2013 11:00 AM
BossHawg,
Are you wanting to put tires in that fill the fenders, what's your ride height, are you planning on tubbing the bed?
These questions all need to be answered so that you get the look you want. You can use a 2WD S-10 rear if you want to run 10" wheels with lots of reverse and tub the box.
If the front is already Corvette, you should do your best to match your track width to the front, don't worry about what the truck was originally. In doing this you have to take into consideration the wheels you will be running and their offset as well.
My 46 GMC on Photobucket
46gmcpu #955918 07/11/2013 10:31 PM
I don't mind changing the offset up a little for track with. I also don't mind tubbing the bed as long as I don't have to do a huge tub... Mini tub I don't mind.
