| | | Forums66 Topics128,205 Posts1,057,425 Members48,471 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2000 Posts: 90 'Bolter | | 'Bolter Joined: Jun 2000 Posts: 90 | I did some searching in this forum but couldn't come up with an answer.
How do 225/70/19.5 tires compare to 8R x 19.5 for working as duals on a '59 3800? The rims are original and have old 8Rs currently. I see more 225/70/19.5s for sale and would use those if the dual tires wouldn't rub. Any thoughts?
1959 Chevrolet 3800 Pickup 1937 Chevrolet GC Panel Can you still call it a barn find if it's your barn? | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | I don't have facts at hand but I believe that you will find that your wheels are too narrow for the metric tires. I found that info somewhere once but I don't remember where it got it.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Jul 2013 Posts: 7 New Guy | | New Guy Joined: Jul 2013 Posts: 7 | I am not too sure if they will rub or not but the width on a 225 is about 8.7" wide and 32.6" tall where an 8r is slightly less than 8" wide and 33.9" tall. But those would vary slightly if your rim is narrower than the recommended width. | | |
