| | | Forums66 Topics128,269 Posts1,058,398 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2009 Posts: 232 Shop Shark | | Shop Shark Joined: Apr 2009 Posts: 232 | I went through several threads before ordering a carter 2100s for my 235. The discussions indicated that they had ported vacuum for the distributor which is what I need. However this is NOT true. The hole is just slightly below the throttle blade and is causing advance at idle. Aside from searching out another carb does anybody have a suggestion? | | |
