7 members (JW51, J Lucas, papas52, Hotrod Lincoln, Gdads51, DadsFirstPickup, 1 invisible),
104
Mod | | | Forums66 Topics128,162 Posts1,056,953 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 73 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 73 | What should I use to provide a good seal between the cab, toe board and floor board? | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Do a search for "Seam Sealer" there are several types. Some are self healing (waxy when cured) and others set up more like butyl caulk.
Depends on your application.
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | CASO knows better than I do, but I think the Factory Assembly Manuals shows "non-hardening" seam sealer (which is available in a calk-gun tube); and, I think this is best applied over epoxy-primed metal - then seal/prime and paint. CASO, would you use the "All-Around" product on the inside joints and the "Fast and Firm" product in the exterior joint, between the upper-cab and lower-cab? Thanks, | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | Tim I don't "know' for squat... I'm just opinionated!
Assuming clean metal is what I'm starting with 3 coats epoxy primer underneath and 2 or 3 inside for sealing the metal. then I'd go for the 3M 8656 on the page you linked. It say's its designed for the seams I believe OP is talking about. If it is between pieces being bolted/screwed together maybe the 8578. I made some gaskets for the headlight bucket/grill/fender seam out of a left over chunk of window setting tape the other day. I was pleased with how it worked into the seam with a plastic edger, trimmed off nice. I imagine the 8578 is like that. Great for sandwiching not for filling a gap. I think the All Around 8500 would be good if your sealing the joints up for paint. Just as long as there's NO SILICONE...
JMO
