| | | Forums66 Topics128,088 Posts1,055,993 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2013 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 32 | Hello all, I recently bought a 64-66 grille support for my 61, the seller told me all I had to do was drill some holes for it to work, but the contour of the surface where the grille sits looks different. Can anyone tell me if my grille will fit in the later support for sure? I know I could pull my grille out and try it, just hoping someone out there knows for sure. Thanks for any help. Ken. | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | I hoped that Tony (4-5-6) would chime in. He will be able to answer this one up without hesitation. I am guessing that the contours may be different, consistent with the headlight configuration change in 62. Will see if my naive response gathers more correct answers. | | | | | Joined: Mar 2013 Posts: 32 'Bolter | | 'Bolter Joined: Mar 2013 Posts: 32 | Hello Hambone, thanks for your reply, and I hope Tony does read this and let me know. Again all help is appreciated. Thanks, Ken. | | |
