1 members (Rnl364), 104 guests, and 6 robots.
Topics128,077
Posts1,056,033
Members48,433
#95459 04/25/2006 4:46 AM
Apprentice
Apprentice
I have a 57 3200 and have installed a new wiring harness but my problem still persists. My fuel and temp gauges don't work. The fuel gauge registers or at least the needle moves, I have a new sending unit, there is a good ground, continuity between the sending unit and gauge and everything is wired according to the shop manual wiring diagram. The only thing that is different from the manual is the spades on my ignition switch don't match the drawing of the ignition switch in the book, but I have looked at other "original" ignition switches from 57s and they were the same as mine. The same basic problem exists with the temp gauge...new unit and continuity. This problem was there prior to installing the new wiring harness. Everything else works fine. I'm at a loss. I just rebuilt the engine and don't want to drive it too much without the temp gauge. Any advice is much appreciated.
#95460 04/25/2006 12:05 PM
OK lets check them,,,first make sure eng has ground to cab and cab to frame...make sure you have power to dash gauges...on the temp gauge,,with ing on gauge hooked up read gauge,unhook eng sender do not let it ground read gauge,ground sender wire read gauge,,gauge should have moved full sweep with wire unhooked then wire grounded,,if not wire to eng unit bad ((unhook wire at gauge use jumper wire do same test with jumper))or temp dash unit bad or no power to dash unit...do same check on fuel gauge...doc
#95461 04/25/2006 12:09 PM
on the fuel gauge the gas tank unit has to have good ground at the tank unit to frame or body...doc
#95462 04/26/2006 11:56 PM
ground??
Jim & Caroline
Z
Z Offline
gound=body. make sure the wire hooked to the body is making good contact.
Apprentice
Apprentice
Thanks for the advice, I'll put it to the test on Friday and let you know what I know. I do know the ground on the fuel sending unit is good and I assume (I know that's trouble) the ground to the gauge panel is good also because the lights work, but I will verify.
Thanks again.
#95465 04/27/2006 11:52 AM
CT..ground==return path to batt -neg vie frame or body because batt -neg is connected to frame or body...doc
#95466 04/27/2006 11:56 AM
58,, the dash gauges donot have to be grounded at the dash to operate,,but the dash cluster must be grounded for the dash lights to operate...doc
