| | | Forums66 Topics128,092 Posts1,056,457 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2013 Posts: 3 New Guy | | New Guy Joined: Jul 2013 Posts: 3 | Hi, My name is Tom This is my first post,just joined.I have a 57 3800 series dump. It was our first truck back in 1970. I want to restore it. My question is will the body panels for a 1/2 ton fit. Doors,fenders etc.I saw a lot of parts on different sites and I think most were for 1/2 ton trucks.We left this poor old truck sit out for the last 25 years so it really needs a lot of TLC. Don't know if it is worth doing, but it brakes my heart to scrap it.Any info will be greatly appreciated. Thank You Tom | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | welcome to the garage Tom, lots of info here and tons of manuals available online here [some 57 ones only listed in the 'by year' section] ... the cabs are identical on all sizes of conventional cab trucks, and front metal is the same for 1/2T to 1T, so you're in luck, all the patch panels available from the vendors [see our links section] will work for you - some of the mechanical hard parts might be scarce, but the parts wanted forum here works well .... they're always worth saving when there's a 'family attachment', go for it  Bill | | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | Welcome Tom, Enjoy the ride at Stovebolt.com! We are here to help. DO NOT EVER be afraid to ask questions! The ONLY DUMB question is the one NOT asked. These guy held my hand and put up with a lot of crap from me but matured me from an ID10T into my ALMOST completed 51 one ton. Jerry Jerry
| | | | | Joined: Jul 2013 Posts: 3 New Guy | | New Guy Joined: Jul 2013 Posts: 3 | Hi, Thanks Bill and Jerry. Well I drug the 57 up to the garage put some gas in, battery and sanded the points. It started right up so I pulled it in the shop over the pit to look it over good. The frame is very good,but the bottom of the cab is pretty bad. As expected no brakes the master cylinder is froze solid. I decided it is worth trying to save. I found two fiberglass front fenders and a seat and gas tank so I guess it is time to go to work. The biggest problem will be fixing the posts where the bottom door hinges bolt. Any info on after-market parts would be helpful.If I can learn how I will post a pic. Thanks Tom | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | hinge pillar patches are available from most of the vendors, you'll likely need the face piece with the opening as well as the 'pocket' piece in behind for those lower hinges - there's also cab mount replacement pieces and various floor sections available a lot of places, check the links section here for vendors, and note that many Task Force [55-59] series patches are available from the normal system via local stores like NAPA, saves shipping Bill | | | | | Joined: Feb 2011 Posts: 1,363 'Bolter | | 'Bolter Joined: Feb 2011 Posts: 1,363 | The cabs are esentially the same, the differences I can think of as noted in the FAM is the lower fender mount points? I think... All the sheet metal patches will work. You can even buy a brand new cab.
Kicking self for selling off my Taskforce trucks. Still looking for an LCF or conventional big bolt in decent shape.
| | | | | Joined: Apr 2005 Posts: 396 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 396 | If I were you, I would Search the world over trying to find Used original fenders before I would even think glass repo fenders. I have read past remarks about glass repos and fitting problems. A search on here and several other sites will probably find that info for you. Just my opinion which with about a buck and a half will get you a cheap,weak cup of coffee in Sleep Eye MN., Jerry Jerry
| | | | | Joined: May 2006 Posts: 26 Wrench Fetcher | | Wrench Fetcher Joined: May 2006 Posts: 26 | Hi Tom you just found the best place in the world to get info and help for fixing up your 57 3800, these guys on here taught me everything and helped me with all my stupid questions its been 5 years for me restoring and saving money to buy parts for my truck but today I finally got her started and drove her down the street. I could never have done it without everyone's help, I still have a ways to go so more stupid questions will be coming, I have found that aftermarket parts suck, if you can save any oem body parts do so, or start hitting the swapmeets, you will find the parts, and most of the time in good condition. those aftermarket fenders are about 450 and then you got to do bodywork and paint on them and make them fit, the oem stuff is always better | | | | | Joined: Jul 2013 Posts: 6 New Guy | | New Guy Joined: Jul 2013 Posts: 6 | Hey Tom,
I am in much the same boat - I just picked up a 3800 myself, and it is my first attempt at restoration. I am learning so much it is hard to believe. Would love to keep in touch through the process, I am sure we will face a lot of the same issues.
Good luck!
first restoration under way! 1950 3800.
