5 members (Waveski, Phak1, Guitplayer, 54farmtruck, MickeyP), 49 guests, and 1 robot.
Topics128,188
Posts1,057,332
Members48,469
Alright, I put 114.4 on the clock since I last checked it, and the results are in. I bought exactly 5.00 gallons in a can to check, and it was 30lbs worth of fuel; so the scale and math works.
In 114.4 miles of mixed driving, driving normally, I atomized 7.9 gallons of 87 octane with that little Rochester 2 bbl; for a total of 14.5MPG.
I'm pretty happy now, the truck drives great; and 14.5MPG I can live with. Only "mod" to speak of is that I bumped the timing up. To 12 degrees initial, IIRC. Carb is stock jetted, idle mixture screws turned in a bit lean from max RPM/vac reading for economy. The engine is a 195HP 283, the 2 barrel car version with the small chamber "power pack" heads. Rams horn manifolds running to a y-pipe and single small outlet OE type muffler. Transmission is the wonderful, indestructible, SM420 truck four speed. I think the rear gears are 4.10, with a 7.50-17 bias mud tire @ 620 revs per mile.
Some of my crap:
1963 C-30 flatbed dually 292/SM420
1965 C-10 LWB fleet 250/column shift 3 speed
1965 C-30 9' stepside 250/SM420/4.10 gears (my DD)
Website I made for my crap:
http://www.66submarine.com
Wow 14.5 I can't get over 10 with my 66 C30 with 292 thats great milage with that truck what kind of bed on your truck mine is a dump
Dave
Mine's a 9' stepside pickup. I have some pictures of it here: photobucket link
Some of my crap:
My first truck was a '66 C-30 9' stepside, and it got around 14mpg.
I have a '63 C30 Dually. 250 straight six, SM420, Dana 70HD with 4.10s out back, 235/85R16 tires (31.7" tall). With a steel flatbed I average about 12mpg. When I first got it on the road with the bare frame rails I got about 15.
1963 Chevy C30 - 292 I6 +.040" 10.78:1, SM465
1978 GMC K2500
"Four gears with a granny low and six cylinders straight in a row."
I'm running 235/85r16's now, too. I just bought a '63 C-30 dually yesterday, BTW. $400 and it even has a 292 and a hot battery! Hoping to get it running soon. Anyway, I pulled it back home on my crappy little 16' car trailer behind the '65. The fuel tank wasn't all the way full when I left, and something like 160 miles later I arrived home with some fuel still left! Must have got 11-12MPG or something. Really surprised me! I drove slow, but there were many, many long hills that I went up wide open all the way, some times I drove in third gear because of heavy rain (or hills), and I wasn't afraid to downshift and use the engine to help slow the rig down. GCW was 12,000lbs+.
Some of my crap:
