0 members (),
115
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,078 Posts1,055,938 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | What would cause a temperature to go to 210 and then return to 180? It will stay at 180 all day but it has to see 210 first. New thermostat checked and it opens slightly before 180. | | | | | Joined: Jun 2011 Posts: 1,901 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 1,901 | It's the time/temp delta between when the unit begins to open (180) and where the sensor/water temp reaches before the water gets cooled and recirculated back to the sensor..
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | mechanical or electric gauge? [I'll bet mechanical] how long does it stay above 180? [I'll bet no more than momentarily]
what could cause it is the gauge being slightly sticky at the bottom of it's sweep
Bill | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | A small bleed hole in the thermostat will stop this in most cases. This allows the stat to sense the temp quicker.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | More data. This always occurred with original 55 2nd electrical gauge and sending unit. I thought I'd fix it by installing after market gauges and a new thermostat ( with bleed hole) Nothing changed. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Boy, you sure like to test us don't you.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | 55.2 would have had a mechanical gauge as 'original'  Bill | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | I never saw a mechanical water gauge, except for a mercury tube. I have a a one wire sending unit with a coil type meter. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | until 56 all original temperature gauges were mechanical, which is what those that operate via a Bourdon [capillary] tube, filled with ether, are called, an electric gauge in a 55.2 would be a replacement, or possibly end of the year production, although the earliest 56's also had mechanical gauges maybe your electric sender isn't sensing properly because it doesn't fit the location as the original mechanical bulb did, I believe the location and hole size for the sender changed for the electric gauge, you may have an adapter there affecting it - here's a mechanical gauge for saleBill
| | | | | Joined: Mar 2010 Posts: 207 Shop Shark | | Shop Shark Joined: Mar 2010 Posts: 207 | Bob, check this site out. I had a problem with my sending unit on my '65 230 and the new sending unit did the trick. http://www.lectriclimited.com/mainpage.htmI was impressed! Tom
Tom 1965 Chevy C10, 230 straight six, 2WD, 4-speed manual
| | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | Thanks Tom, I saved that website for the future. I'm sure on the temp because I measured it with a thermometer. Even though the radiator isn't that old and seems to flow well, I'm going to have it checked out at a radiator shop. Bob | | | | | Joined: Jan 2005 Posts: 75 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 75 | What should a 235 running temp be on a 80 degree day running down the highway starting with a 180 degree thermostat? | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Ive driven my 235 in 100 Plus weather with a 180 stat
maintains 180
up hill gets up to 195
auto meter under dash electric gauge and sender. | | |
