4 members (Rich'sToys, dt235sd, GMJim, 2-Ton), 145 guests, and 4 robots.
Topics128,167
Posts1,057,017
Members48,458
#942544 05/11/2013 10:42 PM
I have a bench seat without the adjuster on it, could someone tell me how the wire is routed through the pulleys on the seat frame?? Or is there a diagram out there?
It's a single loop around all pulleys, but crisscrosses in the middle. At least that's how my '50 is.
Drew
Thanks Drew for the info I will give it a try
I have pics I can dig up of mine when I re-strung the cable. The old one was in place just rusted apart so I was able to reverse engineer it. Let me know...
1949 Chevy 3600
1975 W-25 Hurst Olds
1970 GMC 1/2 ton Fleetside
2010 Chevy Silverado
I have the very same issue. If you could get us a photo that would help a ton!
Also, how long is the cable? 12 feet?? I know it is one loop but mine is cut and measures 12 feet and didn't know if any was missing.
Juiannos(sp) seems to be the place for seat belts. Does anyone know the length for a 53 3100?
https://www.stovebolt.com/ubbthreads/ubbthreads.php?ubb=showflat&Number=908013
...click...
Contact member Roy Rodgers from the thread above. He might have a drawing
DADS50, thanks for the photos.
Does anyone know how long the cable needs to be?? I need to have one made ASAP.
I thought I had pictures some where, but cannot find them. But looks like you have about as good of pictures as I Thought I had.
Red did you find out how long the cable is?
No, I have not found any further information. I need to ASAP! It's hard to drive the truck without a seat!
I just measured the one I took out of this '48.
Roughly 12-1/2 feet. Better start with a 14 foot piece and trim it off.
I always found a milk crate makes a good temp seat. Have to add a pillow when you get old.
Originally Posted by Jim Sears
I just measured the one I took out of this '48. Roughly 12-1/2 feet.
Thanks Jim for the measurement.
Anyone have a photo of how it is routed?
A 5 gallon bucket turned upside down works well also.
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
Moderated by  ndkid275, Phak1
