0 members (), 90 guests, and 3 robots.
Topics128,139
Posts1,056,447
Members48,441
will 1953 3100 rear brake backing plates, drums etc fit my 1950 3100 truck. My goal is to replace the huck style system.
the fronts will fit, I used them on the front of my 46 1/2 ton, you just have to redrill the bottom holes and use spacers and the front hubs and drums will slide right on you're spindles
Why are you replacing the Huck brakes??? Properly installed and
adjusted they stop the truck fine just like any other brake.
They'll lock the brakes up at any speed, I've done it many times.
Now if you're planning on running on a road course that's a different story.
Denny Graham
Sandwich, IL
Denny G
Sandwich, IL
Why are you replacing the Huck brakes??? They'll lock the brakes up at any speed,
yeah like denny said and ive done it also but probably not as many times as denny. i have them on al three of my trucks and they will throw the passenger out through the window. oh and all time you'll save you could be out enjoying a ride. drive
I am missing all of the huck emergency brake hardware both sides....if I could fine what I need I would keep them...any leads for the parts would really help.
I agree with the recent posts. The only reason I can think of is the cost and availability of parts?
David Gilmore
Stovebolt Pictures
Paint progress
____________________________
1950 Chevy 3600
