| | | Forums66 Topics128,167 Posts1,057,020 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 28 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 28 | I am still learning all kinds of things about my truck. I am have been thinking about pulling the leaf springs and either having them rebuilt or buying new ones. I went under the truck yesterday and found that the front had 8 leafs and the rear had 7. Does this make sense to anyone? If I were to rebuild or buy new ones should the rear be 8? It doesn't look like someone removed a leaf from the rear but I am not sure. | | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I would suggest that you look up the specs for the springs on your truck. The number of leaves on the front have nothing to do with the number on the rear ones. | | |
