0 members (),
49
Mod | | | Forums66 Topics128,009 Posts1,055,293 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2007 Posts: 156 Shop Shark | | Shop Shark Joined: Aug 2007 Posts: 156 | I need a new hose for my air compressor. Which is better, pvc or rubber? I had a rubber hose but it developed a lot of cracks and leaks at both ends now. It didn't last as long as I hoped.
Jim
| | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I recently picked up a 1/2" Flexzilla Air Hose and it is very nice, they say it's a Prmimum Hybrid Polymer. The 1/2" hose is approximately the same OD ad the plain old rubber 3/8" hose, so no more bulk, less weight, and more air flow. They make smaller hoses too, and larger. Grigg | | | | | Joined: Feb 2007 Posts: 434 Shop Shark | | Shop Shark Joined: Feb 2007 Posts: 434 | I mounted a 50-foot reel on the wall and that is the cat's meow--no more picking up and coiling hose for storage and much easier to keep up and out of the way.
One day if I ever get to build a dream shop it will be hard lines to outlets every 10 feet or so around the building, with several hose reel overheads because it will be so dang big...
Yeah, I'll keep dreaming...
R-Bo
1959 Apache 1/2 ton Big Window, Short bed Fleetside (under reconstruction) 1966 GMC 305V6 in the family
| | | | | Joined: Jul 2006 Posts: 240 'Bolter | | 'Bolter Joined: Jul 2006 Posts: 240 | I have the Flexzilla on my reel and with 175lbs of pressure it swells up. Don't effect the hose any and still the most flexable hose out there, has went thru one winter and performed well. Was $36 when I got mine now there around $45. here.
You Learn more Listening than Talking
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | Can't say that I was impressed with the Flexzilla hose. We had one installed on a hose reel, a 24" whip hose going from the main line to the reel. We got 1 week out it before it blew out. That was with only about 90-110 psi running to it.
Bill Burmeister | | | | | Joined: Oct 2005 Posts: 4,249 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,249 | Where I work. Plenty of hose reels. Most all of them have rubber hoses. If you get the right kind of rubber hose, they last quite a long time. http://www.bunchobikes.com/pomona1.jpg | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | My preference is rubber over PVC. PVC gets very stiff in the cold where rubber doesn't.
| | | | | Joined: Jul 2012 Posts: 26 New Guy | | New Guy Joined: Jul 2012 Posts: 26 | LB55, If you had a Flesilla failure I'd return it for a replacement. I've met with those folks at their HQ in IA and I'm confident they will stand behind their product. Give them a chance to make it right. | | | | | Joined: Sep 2003 Posts: 2,384 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 2,384 | Dayco service station air hose, 10 yrs on this one. My buddy had no luck with a Flexilla either, it popped when trying to coil it up with air pressure on it. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | I have about 5 automatic 50 foot hose reels in my shop, but my favorite one is the spool with the crank on it. Its a 100 foot capacity reel so I welded a very heavy gauge door hinge on the mount, then bolted it to my compressor cabinet. Now it swings into any position I happen to be standing when I grab it. Been that way for years now. Good idea I got from a local farmer! | | | | | Joined: Jan 2008 Posts: 4,960 'Bolter | | 'Bolter Joined: Jan 2008 Posts: 4,960 | I have at least a dozen crank type reels scattered over the shop. My son installed them when he was in high school and he has been out of school for 20 years. I have them in both 3/8 hose and 1/2 hose. I have oiler/regulators on the 1/2 hose because that is what is used for the more expensive air tools. My preference is Dayco rubber hose. Goodyear puts their name on some real junk. Spring retractable reels are ok, but they are expensive, have springs to break and have a bad habit of retracting the hose while you are under a vehicle trying to change tools. Anyone who is too lazy to crank a hose reel up when they are done is probably too lazy to work for me. | | |
