| | | Forums66 Topics128,033 Posts1,055,531 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#95363 04/15/2006 2:58 AM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Anyone out there know how the headlight and parking light wires are routed on a 1941?? I have made up my own harness and was able to find the route from the switch and dimmer out to the terminal block on the left front fender. From the remnants of the old wiring I can see how it is routed from there to the left headlight. But how were the wires run across to the right terminal block, over, along the radiator tank, or under somewhere along the frame cross member?? | | |
#95364 04/15/2006 3:26 AM | Joined: Feb 2001 Posts: 80 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2001 Posts: 80 | On my 46 there are two J clips soldered on the radiator tank. http://oehmjr46.tripod.com/id45.html | | |
#95365 04/15/2006 5:42 AM | Joined: Jul 2005 Posts: 1,158 Shop Shark | | Shop Shark Joined: Jul 2005 Posts: 1,158 | On my truck, I have a "Farmer Fix" for the starboard head and parking light harness.
A piece of copper wire is acting like a hanger. it's wired to the radiator support.
I have a feeling that it was originally clipped on somehow (probably with clippies similar to the harness attachment to the inner fender on the port side). | | |
#95366 04/15/2006 5:23 PM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | On my 41 Kip, there are two somewhat flexible hooks mounted to the radiator top. It seems like this would get hot and roast but so far it has not. How's the horn coming? I have a horn if you need one. Bert
Greater love have no man than this, That he let his wife drive his truck to the grocery store. ........
#95367 04/15/2006 8:33 PM | Joined: Nov 2005 Posts: 1,048 'Bolter | | 'Bolter Joined: Nov 2005 Posts: 1,048 | Great photos Oehm Jr. Looks like you have some original wiring. On very close inspection looks like my radiator had these clips at one time. Mystery solved, thanks to all !!
Bret: I’ll be in touch about the horn. I have a friend at work who is very good with electrical stuff and I want to see if he can come up with a replacement widget. | | |
#95368 04/21/2006 1:33 PM | Joined: Mar 2006 Posts: 55 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2006 Posts: 55 | Still have the horn and a 41 steering wheel
