0 members (),
102
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | Sirs and/or Madams: I removed the valve cover on a 1957 235 chevrolet car (210 4 door series) engine and found subject problems. My question is can I simply replace the broken rocker arms and the bent connecting rod with items from a 235 1954 engine? Please advise. V/R, Nick Cavallaro, Bel Air, MD
| | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I would look into the cause of the damage. I assume when you say connecting rods you are talking about pushrods. If cause not apparent then change out the broken parts, remove the spark plugs and turn the engine over several times by hand looking for interference. Parts you say are broken are not lightweight parts so if they broke something must be awry. Proceed slowly to avoid further damage.
Ed
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | 1950-56 rocker arms will interchange. Push rods fit 1950-55 with hydraulic lifters and 1956-62 all. Make sure the valves on those broken rockers are not stuck.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Apr 2012 Posts: 415 'Bolter | | 'Bolter Joined: Apr 2012 Posts: 415 | Sirs: Sorry on the nomenclature; yes, Ed I am talking about the push rod being bent at the cylinder closet to the water pump. The broken rocker arms are from two other completely different cylinders. When I bought ($300.00) the free standing engine I had the owner start it and it seemed to run fine, idle, and no smoke. Six weeks later unloaded in my buddy's shop we fired it up again; ran fine, idled, and no smoke. Now I've discovered this issue and want to correct without a substantial teardown. Dave, This engine being a 1957 do you mean push rods are independent froam 1950-55 and 1958-62? Does a 1957 have hydraulic lifters? Please advise. Thanks Ed and Dave. V/R, Nick | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Dave, This engine being a 1957 do you mean push rods are independent from 1950-55 and 1956-62? Does a 1957 have hydraulic lifters? Push rods from 1950-55 with hydraulic lifters and 1956-62 with solids or hydraulic lifters are all the same. (About 11 1/4" long). A 1957 engine could have either solids or hydraulic lifters depending on that it came out of and what has been changed over the years.
