1 members (SlimSix),
129
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,062 Posts1,055,854 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2013 Posts: 173 Shop Shark | | Shop Shark Joined: May 2013 Posts: 173 | I have a 1940 Chevy 3/4 ton special with an original 216 engine (rebuilt). I have a leak around the manifold around the 2nd and 3rd exhaust port.(I can see black exhaust carbon around this area) the bolts are torqued down well beyond any reasonable manner, gaskets are new, tried to double up on gaskets, no avail. Suggestions? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You may need to pull the manifold and put a straight edge on both the manifold and the head. I have seen one or the other or both eroded to a point that a gasket would not hold.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jun 2012 Posts: 69 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2012 Posts: 69 | To add to what Dave said (he helped me with mine) be certain to clean-up each bolt really good with a wire wheel or thread die, also run a tap in each hole to clean it out good | | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | I had the same problem with the two center ports leaking ...pic... I had a machinist deck it for me taking material off the ends then skimming all. ...pic... ...pic... No more leaks Over torquing can crack the manifold | | | | | Joined: Mar 2010 Posts: 10,275 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,275 | Could the lack of contact of two inboard exhaust ports be caused by the intake manifold being a smidge too proud toward the head preventing the exhaust ports from sealing? If this is the case, maybe loosening the two bolts and two nuts that hold the intake to the exhaust together, then bolt it to the head without the gasket for the purpose of aligning the manifolds. Once the the hold down bolts are tight, tighten up the two nuts and two bolts. Use a thin feeler gauge to check for a good fit at the exhaust ports. If everything is flush, take the manifold assembly off and reinstall with the gaskets and check for leaks. A hose held to your ear works good for hearing exhaust leaks.
