7 members (Eisenholtz, Ponchogl, Bill Hanlon, Wayne67vert, 55shaker, Rusty Rod, TUTS 59),
130
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,048 Posts1,055,541 Members48,425 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 17 | Folks, I'm about to weld a patch onto my fender. How do I go about treating the metal that is not welded? I figure that moisture will get between the sheets and start rusting from the inside out. Here are a few pictures. MyBlog Thanks for the help. -Pete | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | Not much you can do. I typically paint the backside (side hidden once both pieces are welded together) with high temp paint. The welding process will still burn off the high temp paint immediately around the welds. If possible, the seams get seam sealer to keep out moisture.
If the repair is simply a patch, I avoid lap welding and use the butt weld method. But, I believe you are talking about two pieces lapped together and spot welded. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you are right, rust will form between lapped panels just as in the original factory pinch welds, the best thing you can do is avoid lapping patches as David says, or use the high-zinc weld-thru primer on the pieces before joining - but be aware the fumes are unfriendly
Bill | | | | | Joined: Dec 2012 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 17 | High-zinc primer... I'll look for it. Glad I asked the question, always something new to learn. | | | | | Joined: Dec 2012 Posts: 17 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 17 | I have a follow up question. I was planning to run a bead along the edges then cut off the excess. I think some folks have indicated it might be better to drill holes then fill the holes. Sort of like a spot weld. What are your opinions on the best method to weld this up.
Thanks again | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | on lap joints, try to mimic the factory spot welds via the plug welding method (I use 1/4" holes). Only do lap joints if the factory did lap joints. Center the hole in the lap. Don't weld the edge of the lap (use seam sealer to keep water out). | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Cold galvanizing spray or weld through primer is what to look for. | | | | | Joined: Jun 2010 Posts: 1,001 Shop Shark | | Shop Shark Joined: Jun 2010 Posts: 1,001 | IMHO, weld through primers still burn off around the weld. Not much you can do about it. I use regular high temp paint and simply use my dremel tool to clean the paint from the area to receive the puddle weld (after parts are assembled, clamped and ready to weld). | | |
