2 members (JeffA, Mike B),
167
Mod | | | Forums66 Topics128,162 Posts1,056,938 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Howdy,
I have recently blasted and painted the torque tube on the 52 3100. Problem is I have the paint too far toward the end of the torque tube and it is thick enough so that I cannot slide the universal ball collar down the tube far enough to clear the u-joint as I did when I diconnected the thing. The slip joint is very tight on the tube where there is no paint (about the first three inches) and is next to impossible to slide over the painted part - and that is without the cork gasket not being screwed on the end. I could beat that thing with a hammer and block of wood and it wouldn't budge.
It appears I need to remove this paint so I can slide the universal ball collar down the tube farther. I just do not know how much to remove. Any advice? 6 inches, 8 inches? I am wanting to remove as little extra paint as possible but need to remove what is necessary to slip that thingup and down the torque tube.
Thank You Scott
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
PANTS UP DON'T LOOT! PANTS UP DON'T LOOT!
NEVER watch another man eat a banana.
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | This much ...click.... Then just remove the cross member, lower the tube and remove everything forward. | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | Thanks for the reply DADS50 - this photo is perfect. I now have a great refernce point for paint removal.
The motor and tranny are not in and this is what is holding me up a bit. I want to slide that ball collar back before trying to poke it into place and didn't want to remove any more paint than necessary.
Thanks Again!
| | | | | Joined: Jan 2010 Posts: 4,263 Shop Shark | | Shop Shark Joined: Jan 2010 Posts: 4,263 | Without the tranny in it might be hard to determine. Here's another pic from a 50 3100 ...click... ...click... | | | | | Joined: Apr 2013 Posts: 165 Wrench Fetcher | | Wrench Fetcher Joined: Apr 2013 Posts: 165 | I figured as much after referencing your first photo. I only have about 3" of bare metal exposed on the torque tube and I will need much more to slide that sucker back.
Thanks!
