2 members (Rusty Rod, baldeagle), 111 guests, and 3 robots.
Topics128,037
Posts1,055,466
Members48,424
#953100 06/27/2013 7:35 PM
Y
Y Offline
I'm in the attempting to revive a 59 235 out of biscayne. While I had the head off I noticed the pistons had .040 stamped on them. I had assumed this engine had never been opened up. So having .040 pistons indicate its been overhauled? Thanks, Phil
It takes considerable cylinder scoring to require a .040" overbore on the first rebuild so there's a possibility it's been done twice. Look for a 10, 20, or 30 stamped somewhere near the front of the block typically indicating how much the crank has been ground.
You Tube
