| | | Forums66 Topics128,047 Posts1,055,532 Members48,424 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2006 Posts: 649 'Bolter | | 'Bolter Joined: Feb 2006 Posts: 649 | I'm in the attempting to revive a 59 235 out of biscayne. While I had the head off I noticed the pistons had .040 stamped on them. I had assumed this engine had never been opened up. So having .040 pistons indicate its been overhauled? Thanks, Phil | | | | | Joined: Mar 2005 Posts: 1,513 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,513 | It takes considerable cylinder scoring to require a .040" overbore on the first rebuild so there's a possibility it's been done twice. Look for a 10, 20, or 30 stamped somewhere near the front of the block typically indicating how much the crank has been ground.
1952 1300 Canadian 1/2 ton restomod You Tube | | |
