1 members (2-Ton),
111
Mod | | | Forums66 Topics128,105 Posts1,056,542 Members48,448 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | What is the preliminary setting for the fuel mixture screw on a Rochester 1 bbl carb (1956)?
Thanks. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 |
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | what ever happened with your overheating problem? | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | I think I got it fixed. I replaced the water pump and put a 7 lb. radiator cap on (still have the 180 degree thermostat on it). I also rodded out the block while I had the pump off, and I had the radiator checked at a radiator shop.
The engine won't idle unless I keep the choke pulled out. Does that mean I have the carb too lean?
Now I seem to have a terrible clunking noise coming from the bottom of the engine after it's been running for a few minutes. I hope it's not a bearing going bad.
I checked the fan for clearance again since I did all this monkeying on the engine because I thought maybe the noise was the fan hitting the radiator tank. I pulled back two of the blades that looked too close. I'll try it again tomorrow. | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | I think I got it fixed. The engine won't idle unless I keep the choke pulled out. Does that mean I have the carb too lean? Something is too lean... Try a couple of these and report back. 1) turn the fuel/air mixture screw in until it "just" bottoms out then turn it out 1-1/2 turns. 2) turn your idle speed screw up a turn or two then start it up and see if it will idle after it warms up alittle. It's not unusual to have to have partial choke when warming up. If it does idle, adjust your speed down to where it will idle then start adjusting the fuel/air mixture screw to smooth it out. Then adjust the idle speed adj to get the idle down where it should be. If it won't idle it's sucking air from an open vaccum line, loose carb to manifold connection, loose manifold to engine connection or the passages in the carb are restricted/plugged up. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | I agree with Volfandt's third suggestion: a vacuum leak (I'd bet on intake manifold to head, but all of Volfandt's suggestions are good).
| | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | I did have the fuel mixture screw turned out 1 1/2 turns from all the way in. I think the timing is probably off a little, too, but it's hard for me to get it idling good enough to set this without the engine dying when I turn the distributor.
I think I'll try turning up the idle speed a tad so maybe I can time it better then; problem is when you turn up the idle speed it changes the timing, doesn't it? Don't know which problem to tackle first, idle or timing.
I have new gaskets on the intake to head connection so I doubt there is a leak there. I had to enlarge the mounting holes a smidgen at the base of the Rochester carb to get it to fit the 216 intake, but I don;t see how it could be sucking air thru the larger holes. I can't think of anywhere else it could have a leak unless there is an extra vacuum port somewhere that I need to plug.
Today I didn't get to run it like I had planned because the original heater shut-off valve was leaking. I think I'm just going to replace it with an inline valve since there isn't anything new available that looks like the original shut-off valve. | | | | | Joined: Feb 2001 Posts: 1,094 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,094 | There are a lot of places it could have a vacum leak. Lets get this truck running, first open the mixture another 1/2 turn, it won't hurt anything the 1 1/2 turns is just a base line setting. You probably do have a vacum leak, On the intake manifold there is a vacum fitting for the windshield wipers, it is under the carb, make sure it is not leaking.Check the hose to the wipers, maybe even plug the fitting till we get thinks running right. The gaskets on the intake, you said you put new ones on, did you use the manifold allignment rings( small metal ring that goes between the manifold and the head), these rings must be staight are it will cause a vacum leak, ASK ME HOW I KNOW. Also check the vacum advance on the distributor, it may be leaking, just unhook from carb and temporarily plug the line. Good luck, keep us informed on the outcome.
Tommy 59 apache 1/2t 261 short stepside | | | | | Joined: Aug 2012 Posts: 1,214 Shop Shark | | Shop Shark Joined: Aug 2012 Posts: 1,214 | A trick I use to hunt air leaks is to use some carb cleaner spray. 1st get your engine to idle at the lwest setting it can without dieing. Use the idle speed screw to set it. Plug all vaccum ports to eliminate a leaky vaccum advance and winshield wiper motor. If the idle picks up once they're plugged you've found your leak. If no change, take the carb cleaner and spray short burst of spray directed at all sealing joints one at a time. Where the carb bolts to the manifold, where each intake manifold runner bolts to the head and around the throttle shaft on the carb. If the idle changes at any location you've found a leak. Remeber to take short bursts while paying very close attention to the engne speed and sound. There should be no change if theres no leak. I've used this method successfully on other engines and should on a stovebolt 6. Good luck Dave | | | | | Joined: Aug 2010 Posts: 182 Shop Shark | | Shop Shark Joined: Aug 2010 Posts: 182 | After all the work I put into the Rochester carb and all the hope I had for it, I had to switch back to the Carter W-1 carb because I want to use the original manifold mounted horn and the inlet for the Rochester carb is directly in line with where the horn goes. The Carter has its inlet offset toward then engine, no doubt to allow space for the horn. Another hard lesson learned. Now I hope I can get it running properly with that old carb.
I decided to take a break from the engine stuff for a few days to try to get the brake system working. | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You should be able to use a 90 degree fitting on the Rochester.
See the USA in your vintage Chevrolet! My Blog | | |
