1 members (baldeagle),
40
Mod | | | Forums66 Topics128,014 Posts1,055,327 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | 1. I just got a new ignition switch with 4 posts in the back: batt, ign, acc, and an unlabeled one in the middle. I'm assuming nothing goes to the unlabeled one in the middle, but I wasn't sure about the acc post. Is that where I put the horn wire? 2. If I add a heater, where would that go? Through the heater switch to the ammeter and a ground? Thanks, Joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | ACC = accessories, usually you would want that to go to a fuse panel to power things like the heater so that they're off when the switch is off - and make sure you have a fuse on the heater .... avoid hooking anything to the ammeter for power .... the horn should have one wire from it to a power point, preferably from a horn relay, the other wire [to supply ground] goes from the horn or relay to the horn button
Bill | | |
