2 members (2-Ton, farmallb), 67 guests, and 4 robots.
Topics128,021
Posts1,055,352
Members48,420
#952991 06/27/2013 11:40 AM
1. I just got a new ignition switch with 4 posts in the back: batt, ign, acc, and an unlabeled one in the middle. I'm assuming nothing goes to the unlabeled one in the middle, but I wasn't sure about the acc post. Is that where I put the horn wire?
2. If I add a heater, where would that go? Through the heater switch to the ammeter and a ground? Thanks, Joe
watsjoe #952999 06/27/2013 12:20 PM
ACC = accessories, usually you would want that to go to a fuse panel to power things like the heater so that they're off when the switch is off - and make sure you have a fuse on the heater .... avoid hooking anything to the ammeter for power .... the horn should have one wire from it to a power point, preferably from a horn relay, the other wire [to supply ground] goes from the horn or relay to the horn button
