| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | I am going to put a '55 rear end in my '53 and use the original '53 leaf springs. Since the center of the leafs or offset forward of center line of the wheel wells do I turn the leafs around to get them more towards center or do I make a plate to atatch to the perches to make up for the offset. Any one with experiance or ideas would be appreciated..photos even better! Thanks Chris | | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | I know I have seen something about this on here before...tried the search without any luck. Anybody flipped the springs 180? Anybody?? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | I don't think swapping the springs will work. I usually weld a extension on the front of the perch with the locating hole in that. The original rear end mounting is about 1 1/2" back from the spring center bolt. Because the tires and wheels look like they are set too far forward in the wheel opening originally I set the rear end back a little farther, about 2". The e'brake cables limit you from moving it back any more.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I am not to sure what you guys mean. We have all run into stuff like this and have answers but I don't have AD, I have TF. Are you using 55.1 or 55.2 rear. I'm sure you know that 55 was transition year from closed to open drive shaft. I guess I just don't know what this means "Since the center of the leafs or offset forward of center line of the wheel wells"??????????????? It does not matter where the center of the leafs are or where the wheel wells are, put the new axle tube in the same place as old axle tube and adapt spring mounting to it. Then no troubles with drive shaft length, axle to spring geometry, ebrake cables or anything else. Just curious: why changing from 53 to 55, would not another 53 be easier? Old one is broken, new one is free?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Up to 1954 has inclosed torque tube drive shaft. 1955 and later is open. The way the axle is mounted to the springs on a closed torque tube set up puts the axle center line about 1 1/2" behind the spring center bolt. This means that when converting to an open drive rear end you can not set the spring perch, with the pilot hole in the center, right down on the spring center bolt. If you did the rear end would be about 1 1/2" ahead of where you want it. Clear as mud I presume.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | Very well said Dave and thanks for the reply. I will probably do what you have done or drll new hole forward of the existing hole of the new perch. Chris | | | | | Joined: Feb 2001 Posts: 1,096 'Bolter | | 'Bolter Joined: Feb 2001 Posts: 1,096 | 53 panel , I made a plate up from some 10mm scrap I had , with a stud for locating the diff and a hole for the spring peg , desired set back , about 1 1/2" I think. I have a '55 rear under my '40. Same issue . | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | Dusty's option is not bad. If you mount the spring pad directly to the spring it will actually raise the truck as originally their is space between the tube and spring. By using a plate between the pad and spring it will help keep the correct ride height.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I gotta see a pic. I think I am following the extension part to pic up the spring hole. I don't get how you make the Ubolts work. But I don't have to know that, you guys have helped him. I am a hanger-on without a cause. Just curious and love to solve mechanical issues. 10mm is 3/8 thick plate. I will study the AD rear ends as I get a chance on the interweb.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | I've done a 1/4" plate with a short allen head cap screw tapped in to place at the right offset. I think I prebent the plate slightly too. It's been a while. | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | If I'm not mistaken, weren't the 54 1st series open driveline? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | The '54s were still closed, but the '55 1st, which more or less a carryover '54 otherwise, is open drive.
Bill Burmeister | | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | OK I get the drilling a new hole forward on the saddles or adding an extension with a hole. So I reckon I have to do the same on the lower plate that goes under the spring that the U bolts attach to, correct?? Chris | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | The lower plates are two piece. The shock mount will be right under the center bolt so you will need to drill a hole in the center of it to fit around the bolt and nut.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jul 2006 Posts: 15 New Guy | | New Guy Joined: Jul 2006 Posts: 15 | So are you saying that I have to make some thing like the original setup with u bolts over that and the springs??? I was thinking that I would be using U bolts over the axle attatched to some kind of plate on the bottom of spring.? | | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | You do need to use U bolts over the axle but you can use the stock plates under the springs if you have them. It is just that the shock mount plate will need to be drilled to fit over the spring center bolt. It does not even need to be drilled clear through, just enough to fit down over the nut.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Aug 2005 Posts: 341 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 341 | Sorry to dredge up this thread, but does anyone who has done this swap have any photos they could share?
Allan ----- 1951 GMC 1/2-ton Two 1953 Chevy 3100 5-window | | | | | Joined: Jun 2011 Posts: 420 Shop Shark | | Shop Shark Joined: Jun 2011 Posts: 420 | http://i629.photobucket.com/albums/uu14/kurtdh519/4-12-12016.jpg .....heres a pic of my s-10 rearswap I did on my 46 1/2 ton ive done alot of these,....ill steer you in the right direction, first off use the original springs, you'll save alot of headaches get yourself a set of s-10 bottom plates to put the u bolts thru (they have the bottom shock mounts built in) and you'll probably have to get a set of spring perches to weld on.....depending on what size width spring you have either 1 3/4" or 2 1/2" (SEE PIC) | | |
