0 members (), 86 guests, and 1 robot.
Topics128,151
Posts1,056,999
Members48,460
I swapped my original 4.57 rear end for a 4.10. Would the 4.57 be called an Eaton HO or something like that?
It's an Eaton HO52.
Bill Burmeister
Longbox,
Thanks!
What would an Eaton HO72 be?
it's essentially the same rearend, but with larger brakes, and perhaps heavier bearings at the wheel ends, which allows for a higher load capacity (7200 pounds vs 5200 pounds). The third members are interchangeable. The HO72 commonly found with the 5.13 gears, but some were 4.56. The HO52 is generally the other way around, with 4.56 being the common one. Both were also available in a 4.10 in some years.
Bill Burmeister
The main difference between the 72 and 52 axles was the 7200lb third member had a load bolt to prevent ring gear deflection with heavier loads as well as double taper roller bearings on the pinion shaft. The 5200lb third members don't have the load bolt and used a double ball roller bearing. The actual axles and wheel bearings were the same between the two. As far as interchangeability the two can be swapped with each other as well as the pinion, carrier and ring gear. The H052 was a 3/4 ton axle while the H072 was used by both 3/4 and 1 ton trucks, suburbans, and delivery vans.
