1 members (Eisenholtz),
59
Mod | | | Forums66 Topics128,022 Posts1,055,377 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2007 Posts: 98 Wrench Fetcher | | Wrench Fetcher Joined: Nov 2007 Posts: 98 | My headlight switch has 5 posts: head, park, batt, tail, and dash. I'm not sure what to do with 2 wires coming off the main harness. They're labeled #10 (headlight switch to instrument lamps switch) and #11 (instrument lamp switch to instrument lamp). Should I hook both #10 and #11 to the "dash" post of the headlight switch? Thanks. Joe | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you've got a Deco series? there was originally a switch under the center of the dash for the instrument lights, so you would have 2 switches as per the labels, #10 would go from the headlite sw to that switch under the edge of the dash, and #11 would go from that switch to the light sockets ... if that sw under the dash is missing, you can substitute a toggle sw
Bill | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | If you have a TF 55-59, I can check my diagrams. I am thinking back to when I did that, right now guessing one wire is hot to switch and the other is power to dash lights? But don't know what vehicle you have? Are you doing a new harness? Who put the labels on the wires?
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | |
