1 members (Eileen), 271 guests, and 2 robots.
Topics128,101
Posts1,056,181
Members48,436
#952180 06/23/2013 10:45 PM
Hi all just wondering I have a 39 chevy pickup with a 216. The problem is when I shut it off the oil starts leaking fast but the goes to a drip.i know there's no seal but not sure what to do to stop the leak any help would be great.
It is true that Chevrolet did not use a rear seal until 1940.
That said I would start by pulling the pan and checking main bearing clearances. If the rear main has too much clearance it can leak oil pressure/oil out faster than it can drain back into the pan. I would also make sure the drain back hole is not sludged up.
My Blog
Ya I'm not sure ill be keeping the motor in the truck now.pushing me to put the small block in it.
Ex Hall Monitor
Ex Hall Monitor
Originally Posted by Weld a lot
.....pushing me to put the small block in it.
People tell me I need to put a small block in my '38. I tell them it already HAS a small block in it (original 216). grin Seriously though it's your vehicle so do as you wish but IMHO when you go to a show you see row after row of lowered, small block Chevy powered hot rods of differing colors. Boring. Then there's my stock '38 sitting tall and proud. Every year as folks turn original cars/trucks into hotrods there are fewer originals & the values rise accordingly. I can't believe what Grundy says my car is worth compared to just a few years ago. To each his own. Just remember it's only original once.
Yeah, that's just the sign of laziness and ignorance (of older engines) coupled with a herd mentality talking... eeeek
Dare to be different! (warning: will require much more patience!)
Give me ambiguity
or give me something else
amen CASO
@caso the whole plan was to put the small block in it but wanted to drive the way it is with the 216. I'm far from lazy so you close your yapper if you don't know.just wanted to know if there was a way to fix it for now.
There is a little ball in the rear main cap that functions as a check valve. If it gets stuck it will cause a leak. The 38 shop manual describes how to free it from the outside using a rod and a hammer.
1951 1 Ton Completed
