2 members (JeffA, Mike B), 167 guests, and 2 robots.
Topics128,162
Posts1,056,938
Members48,458
Guys,
i need the width across the cab floor from lower hinge post to the other side - preferably as close to floor as possible. I took every measurement but this one when began my resto.
I first replaced the lower hinge post and put in a patch using the old floor edge and outer cowl as reference points. Then I moved onto the floor and side rail. But now I have a 3/4 in gap where the hinge patch meets up with the side rail/floor. I have cab x-braced. Fitting up the floor, front cab support. and bracket tells me that the floor is good but I am off on the hinge post. Before I redo, i want to be sure. Hope this is clear. I posted a couple of new pics. thanks
1951 Chevy 3100
Took me a while to find it but here you go
52 car and truck deminisions
I think this is better
54 truck chassis spec's
Give me ambiguity
or give me something else
thanks! i don't know why i am off but it happens.
1951 Chevy 3100
