2 members (dt235sd, Southerntruck), 145 guests, and 8 robots.
Topics128,077
Posts1,056,033
Members48,433
Hello, I am wondering if anyone has ever took the time to measure where the cab would sit on an S-10 frame? I have a 1994 extended cab frame and am trying to make sure I have the my cab place properly. I know there are "jig" holes that could be used as a reference. Just curious. I know I can pin it down but just want to save a bit of time.
Mike
http://www.facebook.com/54bigbolt?ref=hl#!/54bigbolt
http://www.ad-engineering.com/
Send them a message. That is what they are all about. They may give some hints.
Reddie8,
The Truck Factory Assembly Manual has a dimensional frame drawing. It is very useful, the dimensions I needed from wheelbase centerline to firewall were there.
Also check ez chassis swap. They have step by step instructions and the cab mounts all pre-fabed.
My Fleet:
1941
1953
1959
1965
1966
1953 Willy's Pickup
Where it sits on the frame is where you want it to be. Is your 54 a long box or a short box? The reason I ask is because the extended cab frame is the right length for a long box 54, but need to be shortened for a short box.
The reason there is no "measurement" is because it depends on exactly the look you want. We have done several of these swaps now, and always place the cab on the frame with the front end assembled to the cab so you know exactly where to set everything to get your wheels where you want them in the wheelwells.
My 46 GMC on Photobucket
Check my previous posts, I've answered similar questions for a lot of people.
Thanks guys for the links and advice. I have been thinking and thinking on this. Having the front end on is the way to go. I put the fenders on it the day I set the cab down but I am going to bolt them down along with installing the core support.
I am not worried about the bed as I am going to use the stock S-10 bed and do some custom sheet metal work and make it match the contours of the cab.
thanks again guys, Mike
