| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | Got the flywheel clutch and a bunch of other stuff reassembeled onto my 1954 Chevrolet 1 ton dually yesterday. I pulled the old pilot bearing from the crankshaft end and installed the new one which is a roller bearing. Put it all together then installed the transmission. I woke up this morning and started thinking.......was I supposed to put a finger full of grease in the bearing? Tell me I don't have to pull the transmission this morning.
Bruce
| | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | Hi Bruce, You don't want it over flowing with grease but it should be packed around the needle bearings with grease. I think a brass bushing is a better choice for a pilot bearing. Don | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | The needle bearing had just a coating of grease on it, very little. The bronze bushing was shot so I just shoved in the bearing that came with the clutch. I guess I'll pull the transmission now while it's still accessible because I know it won't fail until the whole truck is back together!
Bruce
