Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
3 members (jay d, Southerntruck, 1 invisible), 168 guests, and 6 robots.
Topics128,281
Posts1,058,464
Members48,490
#952025 06/23/2013 7:37 AM
Got the flywheel clutch and a bunch of other stuff reassembeled onto my 1954 Chevrolet 1 ton dually yesterday. I pulled the old pilot bearing from the crankshaft end and installed the new one which is a roller bearing. Put it all together then installed the transmission. I woke up this morning and started thinking.......was I supposed to put a finger full of grease in the bearing? Tell me I don't have to pull the transmission this morning.
Bruce
My Trucks
Stuff I Collect
Hi Bruce,
You don't want it over flowing with grease but it should be packed around the needle bearings with grease. I think a brass bushing is a better choice for a pilot bearing. Don
The needle bearing had just a coating of grease on it, very little. The bronze bushing was shot so I just shoved in the bearing that came with the clutch. I guess I'll pull the transmission now while it's still accessible because I know it won't fail until the whole truck is back together!
Bruce
My Trucks
Stuff I Collect
