| | | Forums66 Topics128,180 Posts1,057,149 Members48,464 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2001 Posts: 58 Member | | Member Joined: Nov 2001 Posts: 58 | Well some good news tonight I started the 350 for the first time. It went on the first try and ran with no bumps or backfires lots of oil pressure and must be almost right on the timing mark etc. "I'm still pulling the horseshoe parts out of my you know where". Anyway the next question is looks like the rad which was recored with new modern fins may be suspect as to keeping it cool enough. Any suggestions on which of the after market rad's are better or worse? | | | | | Joined: May 2000 Posts: 234 Shop Shark | | Shop Shark Joined: May 2000 Posts: 234 | What makes you suspect the radiator? With a recore (even a poor one) it should be cool, unless its way too small for the engine.
Have you checked the thermostat? If it's not opening, that could cause an overheat.
-Boyo
'48 Willys CJ-2A / '55.1 Chevy 3600 / '66 Austin-Healey 3000 / '04 Volvo wagon (parenthood!?)
