4 members (KEVINSKI, 2-Ton, Samantha, mk72), 93 guests, and 2 robots.
Topics128,034
Posts1,055,551
#951874 06/22/2013 11:34 AM
Have a 1950 3100. This has separate adjustments for each side of each wheel in the front. The backs are single adjustment type must be a late 1950 with 1951 rear brakes.Anyway the front is pulling to the right when I brake. Replaced both wheel cylinders a month or two ago. Adjusted the brakes and everything was fine. But just recently it started pulling to the right. I re-ajusted every wheel front and back but its still pulling to the right. Any ideals? Should I put more drag on the left front?
If they are adjusted equal, left and right, and still pull I would check for contaminants on the right shoes.
My Blog
Are the drums, side to side, the same diameter?
Thanks. I never replaced the shoes after I replaced the wheel cylinders. Maybe my cleaning them of brake fuild didn't work as well I thought it did. I guess it time to replace them also. Thanks for your input Thrs 5o
yes
Even though you cleaned the shoes the brake fluid soaked in farther than you could clean. Over time the fluid wicks back up to the surface causing a sticky surface.
You might get away with another good cleaning.
My Blog
Sir Searchalot
Sir Searchalot
Swap them and see if it pulls to the left. I know, if you do that, why not just put new. Be nice to know though? grin
Originally Posted by thrs50
yes
They should be within +/- .010 of each other.
Brake fluid causes brake shoe linings to swell. Same with oil.
Thanks guys for your input. I think I will replace the shoes.
It is too bad you don't also have Huck on the back.
I always swap the shoes contaminated to the rear(where they do not cause pulling to the steering) and a the clean rear shoes to the front .
My Blog
