2 members (JW51, Phak1),
92
Mod | | | Forums66 Topics128,081 Posts1,056,321 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 84 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 84 | If I have a sticky lifter in my 235, can I just... 1- remove the rockers, 2 - take the side cover off, 3 - slide out the pushrods, 4 - remove the lifters 5 - clean the lifters with a carb cleaner to get the varnish off, 6 - put everything back EXACTLY where they came from?
It makes sense to me but I'm not an experienced engine guy so I just wanted to ask. Thanks | | | | | Joined: Jun 2012 Posts: 1,747 'Bolter | | 'Bolter Joined: Jun 2012 Posts: 1,747 | Hydraulic or solid? If all looks good and the lifter is sicking in the block you might have some luck with the plan. If Hydraulic you will need to soak and pump them until clean. Real clean. Really clean. Pull the lifters one at a time, less chance to mix them up that way. Keep the push rods in order so they go back the same way. But the most important thing to figure out...why sticky in the first place. Best way to see what the cam looks like is to pull the pan. That will let you shine a light up and see what you have. Look for pits, scuffing and wear. Same for each lifter. If the engine has been sitting you should check the rockers wile it is easy to see and move them. Do not use any abrasive what so ever. Wash with a clean rag and handle with care. Might just work.
Steve H
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | If they are hydraulic lifters than yes they can be disassembled and cleaned. They will have a snap ring holding them together. They are very simple to disassemble and clean. You may want to look at My Blog for more info.
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Feb 2000 Posts: 5,224 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,224 | Like Dave said. no problem. Pull it out and tear into it, it was assembled once, so why not again?
Joe | | | | | Joined: Oct 2006 Posts: 1,847 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 1,847 | You should be able to make a perfectly satisfactory inspection of the cam lobes through the lifter holes, removing the pan while not technically difficult, is kind of a pain, and would be better left to the absolutely neccesary category in my opinion. That being said this could possibly turn into a can of worms. I went to get the head done on my truck (valves ground, new guides etc.) turned out the head had cracks, chunks were missing out of lifters, and cam lobes neccesitating a cam change, that is when I discovered you have to remove the pan to take the timing gear cover off. Which turned out to be a good thing as there was an incredible amount of crud lodged in it. You will have to make a judgement call of your own on that one.
