7 members (Otto Skorzeny, dt235sd, Cosmo, Hanks custodian, klhansen, JW51, Lostbuthaulinass), 105 guests, and 2 robots.
Topics128,059
Posts1,055,825
#951732 06/21/2013 11:39 AM
Now that I have the front end finished, this weekend I'd like to start on the routing and wiring of the electrical components.
I’m using the E-Z wire 21 circuit and the Dolphin gauges, I’m using analog fuel, oil psi, temp and amps gauges, 12 volt clock and Tachometer. I understand basic wiring, but will probably have a ton of questions on different needs etc.
I also believe in using the right tool for the job, with that being said I would to ask the first advice on the following.
What type stripping tool should I get, an auto wire stripper - self gauging or a manual one?
What type of or brand of electrical connections and /or tape I would think 3-m is the best on the tape?
Jake
1960 GMC 305A V-6 Gallery Page
Remember, the government cannot give --anything to anyone --that they have not first taken away from someone else.
BUY AMERICAN http://www.stillmadeinusa.com/index.html
I finally bought the Ideal Industries Stipmaster, and wish that I had done it years ago. http://www.amazon.com/Ideal-Industries-Stripmaster-Wire-Stripper/dp/B000B5Y9YM
They are not inexpensive, but give great results.
Tim
that stripmaster is way overkill - and note that nearly all the wires you'll be dealing with on a truck will be 10-16 gauge, nothing heavier except battery cables, and anything smaller won't handle any amount of current - also strippers for solid wire can be different than those for stranded, you don't want to be scoring a strand or 2 that will break off later - get a plain simple stripper marked for the gauges and test it on some scrap to insure it suits the particular wire you're using, although skilled use of a knife can do the job well with practice
for connectors [which I'd think were supplied with the kit], use the best ones with the heat shrink sleeves, or at least ones with good nylon covers that stretch when crimped instead of the cheap plastic sleeve ones that get cut or break when crimped - and don't use tape except as a wrap for bundles, and even then expect the ends to come unglued over time - use heat shrink on terminal ends at connections - soldering connectors on is a good idea, but not a necessity if good connectors and crimpers are use with the proper technique
I should do a tech tip about wiring grin
Riding in the Passing Lane
I agree with Red. Use non-insulated terms. Solder thaem & use heat shrink tubeing.
1972 Chevy c10 Cheyenne Super
The Stripmasters may be overkill, but they give great results and are marked for the various gauge wires, both solid and stranded. I've also got the Klein strippers that Red recommends, and do still grab them when in a tight spot, but for fine work I like the Stripmasters.
Tim
