6 members (Woodcmiami, Gdads51, Gib70, Peggy M, Cosmo, 1 invisible), 94 guests, and 2 robots.
Topics128,060
Posts1,055,840
Members48,427
#95171 03/21/2006 8:37 AM
8
8 Offline
I have a 1941 1/2 ton pickup. I have located 5 accessories which are: Radio,fog lights,Heater, defroster, and spotlight. I need to know the proper way to wire them. Do I purchase a fuse block? If so then where do I obtain my hot wire from the lighting swtch or the ignition switch?
Should I use a in-line fuse for each accessory?
I do have the proper delco-remy switches for the heater, defroster & fog lights. One other question. How do you fit a full grown man underneath the dash? I've tried greasing myself up but that leaves a mess in the floor. Thanks
Greater love have no man than this,
That he let his wife drive his truck to the grocery store.
#95172 03/21/2006 12:13 PM
For the first question, on the later AD trucks, accessories like that were fed using inline fuses connected to the ammeter. A fuse block could be fed from the same location and used to supply the accessories.
For the second question, there is no answer! The 47 to 53 dashes are not fun to work on either!
1951 1 Ton Completed
fuse radio and heater from ing sw,,,curcit braker and relay for fog lights and spot...doc
8
8 Offline
Thanks for the help. Didn't they know back then that someday big old heavy farts like me would have to work on these trucks? I quess they would be happy to know that the old truck survived for 65 years. Thanks again for your wisdom. Bert
use a bosch relay for each of the 5 accessories as well as each headlight hi/lo.
http://www.r1200gs.info/howto/relay.html
http://www.stovebolt.com/bboard/cgi-bin//ultimatebb.cgi?ubb=get_topic;f=3;t=001404#000004
http://www.classictruckshop.com/clubs/earlyburbs/projects/bosch/foglites.htm
http://www.ado13.com/techs/relay.htm
and I would have thought you should go 12V.
Jim & Caroline
Make sure that you get the correct Relays, though. 12v relays WILL NOT function on 6v systems. I know. I tried it. grin
8
8 Offline
I have a good foundation now. I think I can wire up these accessories and be safe in the process. I thank you for all of the help. Bert
The ignition switch in the 47 to 53 trucks was not heavy enough to take the load of the radio and the heater. All the factory instructions showed connecting the radio either to the supply side of the ignition switch or the ammeter, using an inline fuse.
