| | | Forums66 Topics128,281 Posts1,058,465 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I switched my 55 1st 6400 back to 6 volt. Now the turn signals don't work. I swapped out the 12 volt flasher silver thingy for a 6 volt and they still don't work. Do the aftermarket steering column flasher units come in 6 and 12 volt or does it matter?
Bruce | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | wires and switches don't care about volts .... did you change all the bulbs back to 6V, including the indicator bulb? are you sure the 'flasher silver thingy' is wired correctly? do the other lights work?
Bill | | | | | Joined: Aug 2005 Posts: 1,186 Shop Shark | | Shop Shark Joined: Aug 2005 Posts: 1,186 | I did change the bulbs but not the one in the flasher unit itself. The headlights work as do the tail lights just no flashers. I looked again today (between rain storms) and noticed I only have two wires going into the flasher socket. I'm not the most flexable person and it's hard to see under the dash with my bad back. Not sure if I unplugged one wire when I changed the silver thingy but they did work on 12 volts. Are there supposed to be three wires plugged into the socket?
Bruce
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, 3 wires on the flasher, see here, one a power lead, one for the load [signal unit], one for the indicator, you may be missing the power or load wire Bill | | |
