Brrrr
Winter is Coming
A good Tech Tip
WINTERIZING YOUR TRUCK
2 members (55shaker, Wayne67vert), 118 guests, and 4 robots.
Topics128,281
Posts1,058,465
Members48,490
#951700 06/21/2013 7:52 AM
I switched my 55 1st 6400 back to 6 volt. Now the turn signals don't work. I swapped out the 12 volt flasher silver thingy for a 6 volt and they still don't work. Do the aftermarket steering column flasher units come in 6 and 12 volt or does it matter?
Bruce
My Trucks
Stuff I Collect
wires and switches don't care about volts .... did you change all the bulbs back to 6V, including the indicator bulb? are you sure the 'flasher silver thingy' is wired correctly? do the other lights work?
I did change the bulbs but not the one in the flasher unit itself. The headlights work as do the tail lights just no flashers. I looked again today (between rain storms) and noticed I only have two wires going into the flasher socket. I'm not the most flexable person and it's hard to see under the dash with my bad back. Not sure if I unplugged one wire when I changed the silver thingy but they did work on 12 volts. Are there supposed to be three wires plugged into the socket?
Bruce
My Trucks
Stuff I Collect
yes, 3 wires on the flasher, see here, one a power lead, one for the load [signal unit], one for the indicator, you may be missing the power or load wire
