6 members (55shaker, 1955 1 Series, Steveoreno, 3B, Doug Boudreaux, Bill Trotter), 84 guests, and 2 robots.
Topics128,200
Posts1,057,405
Members48,471
Junior Member
Junior Member
i am looking to get some brakes going in my 46 1 1/2 flatbed. what are my best options? a total brake swap or the rebuild? i am redoing this as a work truck so i would like a good user for the job at hand. this thing has been sitting a long time.
Options?, a lot of work, far more than just rebuilding what ya have. The stock brakes are a fairly good size for gross weight in the 10-12k lbs weight range.I have a 45 Chevy 2 ton, did the brakes a few years ago.Relined shoes from a local brake shop,new master,new wheel cylinders, the drums were in great shape.The truck stops just fine considering it's 45 mph cruising speed.If you carry heavy loads you might want a Hydovac assist.Remember to check the rear wheel bearings and buy new seals, and beg, borrow or steal a wheel dolly to support the whole dual tire assembly,makes the job a piece of cake.
Junior Member
Junior Member
when the engin is running my brake pedal is sucked to the floor. does this mean that my vacuum cylinder is bad??
