7 members (Shaffer's1950, Steelonsteel, Hotrod Lincoln, 2-Ton, homer52, Tiny, mo2cyl), 112 guests, and 3 robots.
Topics128,049
Posts1,055,665
#951421 06/19/2013 8:23 PM
Question - if I remove the valve cover on my 1954 235 3100 to paint it,do I have to replace the gasket when I reinstall the cover? It does not leak now. Thanks.
harryr #951465 06/19/2013 11:21 PM
It depends upon the condition of the gasket. I have reused a valve cover gaskets many times. I have also never over-tightened the screws on the valve cover.
harryr #951467 06/19/2013 11:24 PM
Proper installation is glue the gasket to the cover and oil the mating surface of the gasket. If yours was done that way it should come off in one piece. If it was pookied on both sides, probably not.
Thanks! What do you recommend for the "glue".
I do mine the other way around, I glue it to the head, that way there is a small "moat" to help keep the oil in. It is probably more psychological than anything else, but it seems to be working. I don't remove the valve cover enough to worry about cleaning the goo off once in a while.
harryr #951716 06/21/2013 10:22 AM
i like to glue both sides. that way when it needs to come off it's like an old fashion western knife fight grin
actually i do like brokenhead does by glueing it to the head and like tim does by not unevenly over tightening it. using a "best: gasket it will last a very long time with no leakage.
harryr #951740 06/21/2013 12:44 PM
i glued both sides of the gasket just to be safe
Indy wink
1949 Dodge Coronet
1955 2nd Chevy 4400 1.5 ton
1955 2nd Chevy 3100 1/2 ton
1957 Chevy 5400 LCF 2 ton
1966 Dodge D100 Sweptline
1968 Chevy P20 stepvan
1969 GMC LWB pickup
1972 GMC Sprint
1974 CP30 shorty bus
I don't glue either side grin .
My Blog
