| | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Installed a temp gauge and sensor in my 58 Chevy. Manual gauge shows engine to run pretty consistently at 180 degrees.
When I hook up my temp gauge in the dash after about tem minutes it will be pegged out. Install the old gauge and it too will eventually peg out even with the new sensor.
If the wiring from the back of the gauge to the temp sensor is bad will it make it eventually peg?
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | the wire to the sender will be a "go/no go" thing, just conveying the resistance info from the sender, if you give the wire an ohmmeter check it should read near 0 ohms end to end ... are you sure you have the correct sender? no thread sealant of any type on the sender? NAPA TS6469
Bill | | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | Supposed to be correct sender. No sealant. I've read on other forums that some brands work better than others. | | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | never had any problem with a sender, but you can heat it in a pan of water on the stove with a thermometer, while watching the ohm reading, should move steady and not get to a max [or min] reading until the water is really boiling - if it's causing your gauge to peg at a true 180 it should show up
Bill | | |
