2 members (Rusty Rod, porsche), 64 guests, and 3 robots.
Topics128,021
Posts1,055,357
Members48,420
#951062 06/17/2013 11:22 PM
Installed a temp gauge and sensor in my 58 Chevy. Manual gauge shows engine to run pretty consistently at 180 degrees.
When I hook up my temp gauge in the dash after about tem minutes it will be pegged out. Install the old gauge and it too will eventually peg out even with the new sensor.
If the wiring from the back of the gauge to the temp sensor is bad will it make it eventually peg?
the wire to the sender will be a "go/no go" thing, just conveying the resistance info from the sender, if you give the wire an ohmmeter check it should read near 0 ohms end to end ... are you sure you have the correct sender? no thread sealant of any type on the sender? NAPA TS6469
Supposed to be correct sender. No sealant. I've read on other forums that some brands work better than others.
never had any problem with a sender, but you can heat it in a pan of water on the stove with a thermometer, while watching the ohm reading, should move steady and not get to a max [or min] reading until the water is really boiling - if it's causing your gauge to peg at a true 180 it should show up
