7 members (RoadsScholar, frogfarmer, klhansen, Otto Skorzeny, UtahYork, 1955 1 Series, greenie-reddy), 150 guests, and 1 robot.
Topics128,087
Posts1,055,974
Members48,430
#950846 06/17/2013 10:15 AM
I'm outing a 52 216 in my 49 gmc until I can get my 228 rebuilt... Problem is, the 216 is shorter than the 228 and the mounts don't line up. Has anyone done this type of swap before? Is there a kit out there for this? Please help...
No simple fix... If your planning on using the 228 a 270 would fit better if you can find one in the mean time. Same size block and mounting.
Give me ambiguity
or give me something else
Crusing in the Passing Lane
Also 236, 248, 256, etc., same block.
Also 236, 248, 256, etc., same block; for that matter, 230, 250, 292, although bellhousing slightly different, pedals mount differently.
Unfortunately, my only option is the 216 and trying to make that work. I'm thinking of building a bracket to mount the front and using a spacer on the fan.
if you replace the front crossmember with one from a chevy it will bolt in. your fan will be 2" further away from the rad. and you'll need slightly longer hoses. you can make a plate to adapt the front mount.
Then you'll just need to swap it all back when the 228 is ready...
Is the 216 just a 'short term' transplant so you can drive for now? Or is this going to be how it runs for a few years? What you do now that has to be undone later only seems worth it if your waiting a while on the 228 to me...
Give me ambiguity
Yes, the 216 is just short term until the 228 is ready. Probably wont be in there for more than a couple of months, but I want to be sure to have something substantial enough for Longer if necessary.
Do you think just a plate up front will work? It looks to me like the rear mounts do most of the work and the front just kind of rests there.
plate up front would work, ive seen um anywhere from crude to looking original. since its only going to be a couple of months depending how the rest of the truck is i could find lots of things to do with the engine,tranny and front end removed without going through the trouble of putting in a 216 short term laalaa
I have installed many Chev engines in GMC's by making a plate to move the front mounting position back enough for the Chev.
You will also need to modify the exhaust head pipe and throttle linkage.
My Blog
I wonder if you can buy a plastic shroud for the fan. If so that would solve that problem.
Pre68 Dave,
how does the plate work? Do you just make it thick enough so it can't bend or do you put vertical flanges on it?
1951 1 Ton Completed
Why not drive the 228 until you can get a 270 or 302 rebuilt?
I use a flat plate bolted to the original holes on the frame and extending back enough to catch the Chev engine.
The clearance for replacing the fan belt can be a little tight with the larger 235 balancer.
My Blog
I have a 51 gmc that had a 216 in it. All they did was mount a plate with the proper offset on the holes and it worked great.
49 chevy 1-ton. It is a work in progress but it's getting close. 49 1 Ton Pics
Problem solved...built a plate that bolts on the bottom of the engine and bolts to the top of the motor mount, which is still mounted to the frame. Thanks for the help...
Some folks make everything harder than it really is. smile
Congrats on getting the 216 in. (Hey, you might like it.)
Professional Novice
