| | | Forums66 Topics128,180 Posts1,057,165 Members48,465 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | hello chaps. just rebuilt my engine ( no machine work), new head gasket ect..drilled the head steam holes... now beside the distributor and to the front of engine ive oil leak which dribbles out when reving?....whats best to do? ive tighted it down again hot. its not a copper gasket.?
should i torque it more? dont really want pull head off again?
1953..panel truck.I love my truck!...
| | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | its it possible the oil could be coming up the threds of the head bolt? i didnt use any sealer on the bolts? its got such pressure when it comes?
| | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | one more thing to add, is that ive put 10-30 oil in, im running the down draft tub and venter rocker box cap? when i put my hand over the rocker box "oil fill" hole...the leak is loads worse....?
| | | | | Joined: Jan 2001 Posts: 5,337 'Bolter | | 'Bolter Joined: Jan 2001 Posts: 5,337 | There is some clarification needed. The only head bolts on the distributor side are under the valve cover. The only head bolt that goes into an oil supply is the center outer one on the distributor side, the rest go into blind holes. Can you post a picture of where the oil is coming from?
See the USA in your vintage Chevrolet! My Blog | | | | | Joined: Jan 2013 Posts: 1,384 Shop Shark | | Shop Shark Joined: Jan 2013 Posts: 1,384 | That means that the oil is coming from an un-pressurized source, like a return galley. When you block the vent the air pressure increases in the rocker cover and helps push out the oil. Sounds like there is a fair amount of blow by.
Did you check that the head was flat and there was no damage to block or head, in this case, around the oil return holes and push rod holes? Most likely oil returning from the rockers is pooling on a mis-match (common) of gasket or castings at the head/block joint and the pressure is helping it find it's way out through a bad gasket or poor sealing surface. | | | | | Joined: Mar 2010 Posts: 74 Wrench Fetcher | | Wrench Fetcher Joined: Mar 2010 Posts: 74 | thanks guys....ive just taken the head off...and the gasket is cut so close to the edge its unreal...looks like its drifted also when i put the head down to make it worse..
i will post a photo when home so others can try avoid this problem..
i have another gasket set but belive it will still be way close to the edge and have to try using alot of sealant.
| | | | | Joined: Nov 2000 Posts: 1,972 'Bolter | | 'Bolter Joined: Nov 2000 Posts: 1,972 | Do you have any alignment pins to guide the head down into place? Several years ago I made some from a couple of extra head bolts. Sawed off the heads and cut a slot for a screwdriver. It helps to keep the gasket from drifting.
Professional Novice
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | In response to your previous question, I would suggest never going over the stated torque limit on the head bolts. | | |
