1 members (klhansen),
92
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,741 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | The schematic in the factory assy manual does not show a fuse block or in line fuses. i bought an harness for the 53 that didn't come with any fuses. does anyone out there have a schematic that shows a good spot for a fuse block and which wires i should fuse. or which wires and where i would put an inline fuse. i'll also be wiring in the blinker switch so a good location for the flasher too. i notice a lot of wires connect to the ignition switch would it be advisabble to use a terminal block and run one wire to the ignition switch? thanks rolf
1963 c10 | | | | | Joined: Aug 2005 Posts: 6,377 Ex Hall Monitor | | Ex Hall Monitor Joined: Aug 2005 Posts: 6,377 | I don't know when Chevy went to a fuse block arrangement. My '38 has one fuse from the factory, on the ammeter. Every accessory (heater, defroster, fog lights, radio, etc.) has it's own in-line fuse. My headlight/taillight circuit is fused by the main fuse which isn't really a good idea but I haven't added an in-line fuse to that circuit. Basically anything drawing power should be fused.
| | | | | Joined: Sep 2003 Posts: 200 Shop Shark | | Shop Shark Joined: Sep 2003 Posts: 200 | Don't know about 53, but my 51 has two fuses on the firewall driver's side for the tail light and brake light. Everything else goes through the light switch which has a bimetallic breaker. My heater motor has an inline fuse, but it was an option, I believe. Hope that is some help.
Mark
1951 Chevy 3100 Some days you get the bear. Some days the bear gets you.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | this diagram shows a fuse block with 2 fuses, under the hood, for the stop and tail lights .... for other electrical items, it would be a good idea to have one wire for switched power going to an aftermarket fuse block, maybe on the firewall above your left foot or on the left side kick panel Bill | | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | thanks guys
since the truck is wired original (well 12v) except for the addition of the heater and electric wipers, i'll leave all as is and put in line fuses on the heater and wipers. 10 amp fuses for those motors?
thanks again rolf
1963 c10 | | |
