3 members (Woodcmiami, Bill Hanlon, 2-Ton), 108 guests, and 2 robots.
Topics128,109
Posts1,056,258
Members48,437
#95062 03/13/2006 1:31 PM
Junior Member
Junior Member
55 GMC 12volt Ign coil is marked that it doesn't need a resistor. But I think that you would still need to install a resistor to the original gas guage. Am I right or wrong ?
Phxamigo
Phxamigo
#95063 03/13/2006 1:59 PM
If your truck was originally a 6 volt truck and you still have your original 6 volt gauge, then you will need the resistor for the gauge. The reason 12V coil does not need a resistor is because the resistor is built into it.
Jim
1954 GMC 1/2-ton Longbed
1971 Pontiac LeMans Sport
#95064 03/16/2006 10:17 PM
When did GMC change over to 12 volt system? i thought it was 55, but could be wrong.
"It ain't a truck if you can't hose out the cab."
#95065 03/16/2006 10:44 PM
amigo - the ignition resistor required for a coil has nothing to do with the dropping resistor required for using a 6volt gauge on 12volts, so yes, you still need that as Jim sez
Chester, I think GMC was a year behind Chev and used 6volt in 55, 12volt in 56
#95066 03/17/2006 4:39 PM
I am not sure about this and hope that someone who is certain will correct me. American GMCs used 6v positive ground on 6 cylinder engines through 1955-2nd series and used 12v negative ground on V-8s on 1955-2nd series trucks (as standard equipment - some models had optional voltages).
#95067 03/19/2006 12:25 AM
I am not in a place i can check the referances. but my 39 chevy 6 has 6 volt neg ground.
#95068 03/19/2006 12:34 AM
yes Chester, but GMC used positive ground for years back then
